Phones firmware upgrade when upgrading to CCM 6.1.2
Jan 14th, 2009
  • Gold, 750 points or more
Hi Netpros,
I have a question regarding firmware upgrade for phones which will be migrated from CCM 4.1 to CCM 6.1.2 . The phones are 7960 with the below loads
App Load ID P00307020400
Boot Load ID PC03A300
Version 7.2(4.0)
In the event that firmware upgrade is actually required. Would the firmware upgrade need to be performed before the CCM upgrade or would the new firmware install automatically to the phones as they register with the new CCM 6.1.2
As always your feedback is much appreciated !!!
Overall Rating: 4 (1 ratings)
Rob Huffman Wed, 01/14/2009 - 15:38
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Fernando,
When this upgrade is performed the Firmware for the 7940's/7960's will be upgraded as well as part of the process. What many people do to speed up the upgrade process is to find out what the Firmware will be on the 6.x build and upgrade the IP Phones ahead of time. Either way you win :)
Hope this helps!
Rob
Fernando_Meza Wed, 01/14/2009 - 19:01
Hi Rob,
Appreciate your comments. I would prefer to schedule one down time only (when the CCM upgrade is going ahead) rather than doing it several times (as phone's firmware gets upgraded before hand and finally when CCM is upgraded). However I am concerned about a couple of remote locations if I decided to doing it on one hit . hmmm .. I need to sleep over it :-)
Cheers,
