High Memory Usage IPCC 5.X
Jan 14th, 2009
We just installed IPCC 5.X and we are experiencing high memory usage. I have looked in the task manager and it has multiple instancase of the same process for example one is "NMWRAPPER.EXE" and the CRS processes are using a lot of resources. Is there something I need to do? Or does the box have to be rebooted? Please see the screen shots that are attached.
Anonymous (not verified) Tue, 01/20/2009 - 08:54
To verify the issue do the following:
- Run virus scan on server to see no virus on the box.
- Change the LDAP connection of the CRS box to point to anther CallManager that working fine and see if the problem remains the same
