CME- How can i make outgoing PSTN calls only with a key like FAC (in cucm)
Answered Question
Jan 14th, 2009
I would like to know if it is possible to assign something like FAC (Forced Authorization Code in CUCM) for each user in a call manager express enviroment to make outgoing PSTN calls. if the user does not have a key, he cannot make outgoing PSTN calls.
Correct Answer by filiberto.aguirre about 8 years 5 days ago
hola manuel,
no te funciona porque primero necesitas que el CME verifique la marcación,una vez validada el CME lo manda por el puerto analógico. en el ejemplo que te envié aparecen 2 dial-peer , el primero es un voip que es el usa el CME para recebir los datos del PIN, el otro dial-peer es un pots.
haz la anologia con el ejemplo que te dí pero ahora, la diferencia es que yo te envie uno con un controllador e1 y tu usas una troncal analogica.
saludos
Overall Rating: 0 (2 ratings)
Paolo Bevilacqua Thu, 01/15/2009 - 03:58
The simpler way is "afterhours and pin override" - check CME documentation. All other methods involves TCL scripts, that is a bit more complicated.
Nicholas Matthews Thu, 01/15/2009 - 05:46
Hi Manuel,
Forced Access Codes (FAC) is not currently a supported feature. This feature is in the roadmap for CME, but it does not have any current support. This isn't to be confused with Feature Access Codes (FAC), which is a different FAC :)
Here's a link from the CME support wiki that outlines the steps and guides, as well as provides the script:
http://supportwiki.cisco.com/ViewWiki/index.php/SBCS:Call_Handling_-_Cisco_Unified_Communications_500_Series_-_Cisco_Smart_Business_Communication_Systems#Can_UC500.2FCME_be_configured_to_prompt_a_caller_for_a_PIN_before_placing_a_call.3F
hth,
nick
filiberto.aguirre Thu, 01/15/2009 - 13:39
Hi manuel,
some months ago I found this info in tis forum,is aplied to UC500 buy I set in my CME 7.0 , it works but sometimes the PIN is not asked, I don't know why, maybe is a bug
1) IP Phone user dials a particular pattern (international destination, for example)
2) If this destination is enabled for FAC, the user will hear a voice prompt asking for an Account number and PIN
3) The user enters the Account/PIN pair. If valid, the call proceeds, if not the call is dropped.
Configuration Steps
1) Obtain the application package from our FTP location. The package contains two audio files that need to be moved to the UC500 flash:
Simple-FAC-SBCS.zip
2) Copy the individual audio files to the UC500, using TFTP for example.
3) Enter the following commands in configuration mode, to load and activate the script (in this example the Account and PIN are three digits long):
application
service clid_authen_collect
param uid-len 3
param pin-len 3
4) Create usernames for authentication. Notice that the username/password will represent the Account and PIN that the caller will have to dial to be successfully authenticated. You can create multiple usernames and then hand those out to select personnel that will be allowed to place premium calls. In this example both Account and PIN are three digits long. The system supports a maximum of 16 digits for codes:
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
username 123 password 123
username 321 password 321
5) Create a dial-peer for each pattern that you want cover using this application. Start with index 2500. In this example, only one dial-peer is shown with 9011.T as the pattern, which is the International prefix in the US. Notice that the pattern is preceded by an access code (9) that could vary per implementation:
dial-peer voice 1000 voip
description cell nal PIN
destination-pattern 9045..........
session target ipv4:x.x.x.x ---------------> CME IP
incoming called-number 9045..........
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1001 pots
corlist outgoing LADA-cell
description cell Nal PIN
port 0/2/0:1
prefix 045
Limitations and Considerations
- This feature does not support any reporting or CDR insertion, which means that Call Detail Records won't display the account number used to place the call.
- If the authentication fails after three retries, the call drops without notification.
- Some features, such as transfer, call forward, etc. may not work.
manuel.giraldo Fri, 01/16/2009 - 10:18
Hi filiberto:
First of all, thanks a millions for your e-mail. I want to explain what i did after your advice.
1. I uploaded the two files which are enter_account.au and enter_pin.au to the flash memory.
2. I entered the following commands in the configuration mode:
application
param uid-len 6
param pin-len 6
3. I created the user: (configuration mode)
username 123456 password 123456
4.- I configured the following dial peer:
dial-peer voice 1 pots
corlist outgoing Servicios
description Conexion a PBX
destination-pattern 9... >>> ext with 3 dig
port 1/0/0
voice-port 1/0/0
station-id name PBX
Note:This port connects the CME to a PBX. port 1/0/0 is FXS.
dial-peer cor custom
name servicios
dial-peer cor list Servicios
member servicios
ephone-dn 1 dual-line
call-waiting ring
number 207
description Engineering
name Manuel Giraldo
corlist incoming Servicios
ephone 1
description Manuel Giraldo
video
mac-address 001E.4A5F.ED5C
paging-dn 6
type 7911
button 1:1
After those steps, i made a test call but the cme never asks me the key. Calls progress without problem.
Are there anything else i have fogetten?
By the way, maybe you are latinoamerican, if it is so, could you write in spanish?
Thanks in advanced.
Correct Answer
filiberto.aguirre Fri, 01/16/2009 - 13:46
hola manuel,
saludos
manuel.giraldo Fri, 01/16/2009 - 16:11
Estimado Filiberto:
Acabo de configurar los 2 dial peer y funcionó tal como indicaste. Cuando marco 9107, el cme busca un dial-peer y por jerarquia u orden ya establecido busca los incoming called number de estos(inbound dial peer), despues del match busca los destinattion pattern de los dial peer(outbound dial peer), y es por ellos que si funciona.
Nuevamente Muchisimas gracias Filiberto.
filiberto.aguirre Fri, 01/16/2009 - 17:19
Excelente Manuel,
yo tengo la version de CME 7.0 y en ocasiones no me pide el pin, si tienes una version diferente y te pide siempre el PIN que es como debe de ser me avisas.
yo tengo la 2800nm-adventerprisek9-mz.124-20.T.bin
saludos!
manuel.giraldo Fri, 01/16/2009 - 19:42
Filiberto,
Yo tengo el CME 4.0, También tengo el detallito de que a veces no pide la clave. Probaré con otros ios para ver si el prob persiste. Ahora me falta ver la integración entre el Microsoft Office Communicator y el CME, segun comentarios indican que se debe hacer un sip trunk pero debo leer porque del tema no se mucho, si tienes alguna info que me pudiera servir, te agradeceria mucho enviarmela. Quise preguntarle ese tema a tony pero encontre cerrado el foro.
Asimismo tengo por tarea configurar una conferencia pero con más de 3 usuarios dentro de ella. Esos 2 temas debo resolverlos, si te has cruzado ya con alguno de éste, please help me!!
Gracias de Antemano,
Manuel
andresfmg Wed, 03/23/2011 - 17:25
amigos, eso se resuelve colocandole preference 0 al dial-peer voip y preference 1
al dial-peer pots
saludos!!
filiberto.aguirre Tue, 05/22/2012 - 06:03
CME 8.6 and later support FAC feature.
For previous version I found in this forum a solution that I have modified based on recommendations I received (check all the post). You can try if you wish.
Last modification I have to do was the preference option in dial peer (thanks to andresfmq for this tip).
dial-peer voice 50 voip
description Cellular Calls
destination-pattern 9044..........
session target ipv4:10.10.10.1
incoming called-number 9044..........
codec g711ulaw
no vad
dial-peer voice 51 pots
PREDERENCE 1
corlist outgoing  Cell
port 0/1/0:0
prefix 044
dial-peer voice 52 voip
description Cellular LD
codec g711ulaw
no vad
dial-peer voice 53 pots
PREFERENCE 1
port 0/1/0:0
prefix 045
Seifeddine-Tlili Tue, 05/22/2012 - 09:39
Hi Filiberto
Thanks for the TIP, i`ve actually thought of it but i was afraid that it will cause a loop (looping on the same dialpeer)
The issue that i had was a weird random round robin between my pots dialpeer and voip dialpeer and what doesn`t make sense that in my voip dialpeer i have the incoming called number which should be the ASSET to have the voip dialpeer selected first
i`ll do a test with my customer and let you know
Thanks mate
