Using CCM Directory between two clusters
Jan 15th, 2009
Hi all,
In our company we have two callmanager Clusters ( Site A 4.1.3 ; Site B 6.1 )
Before we did an Upgrade on the one site we could use the directory from the other side as well as our own, but since we did the update the users can only access their own Site directory an when they try to access the other directory the phone shows a 404.
I looked at the enterprise parameters but did not find a fault, did cisco change the method of accessing the directory between the two version?
Do I have to change settings in the URL or in the XML/ASP file?
kind regards
Christian
Overall Rating: 3 (1 ratings)
christianluven Fri, 01/16/2009 - 01:34
Is there a possibility to merge/change the files so that each site can access the directory of the other side or should i wait until the old callmanager is updated in the middle of february?
