ip broadcast address
benson.low
Dear Netpro,
I am curious to the usage of ip broadcast-address. I have a loopback address defined, e.g
interface Loopback0
ip address 1.2.24.70 255.255.255.255
ip broadcast-address 1.2.24.70
However, when the NMS do a snmpwalk to this loopback, the router is able to receive and reply back, but to the NMS, it just time out.
Extract from router's log:
Jan 15 17:07:09.827 UTC: SNMP: Packet received via UDP from 1.8.28.5 on Fast
Ethernet0/0
Jan 15 17:07:09.831 UTC: SNMP: Get request, reqid 217043, errstat 0, erridx 0
sysUpTime.0 = NULL TYPE/VALUE
Jan 15 17:07:09.843 UTC: SNMP: Response, reqid 217043, errstat 0, erridx 0
sysUpTime.0 = 4078928607
Jan 15 17:07:09.851 UTC: SNMP: Packet sent via UDP to 1.8.28.5
The way to solve this issue is to remove the ip broadcast-address from the loopback 0.
Any one able to shed some light in this area?
Rgrds,
Benson
Tshi M
Level 5
Level 5
Loopback is used on devices because it is an interface that never goes down. However, I don't know if this is the answer but I would not use ip broadcast-address on the loopback address since it is a /32 host.
my problem starts with the use of command ip broadcast-address. If it is removed, the NMS is able to do a snmpwalk to the loopback address. Otherwise, only snmpwalk of physical ip addresses are possible. This is weird as I do not see this sympton before.
