Static route to the net behind ipsec tunnel from pix 506e 6.3(5)
Jan 15th, 2009
Good day.
there are networks: connected through the pix506e 6.3(5) and throug the router 2851 using ipsec.
routers ip are:,
Now i need an access from to the wich behind
How i must setup pix? In router configuration it's simply by ip route etc...
But on pix configuration route outside isn't take effect :(
so scheme will looks like this:
( inside)PIX(outside)---INTERNET---c2851(
p.s. sorry for my owful english.
Jon Marshall Thu, 01/15/2009 - 03:45
Hi Andrew
"You also need a static route to point the out of the outside interface, so the PIX knows it needs to encrypt it."
Not sure you do. As long as the pix knows how to get to the IPSEC peer ie. the 2811 on it's public address then adding the network to the crypto map access-list is enough ot make it work. The pix then knows it needs to be encrypted and simply encapsulates the packet and sends it to the public IP of the 2811.
Mind you it's been a while since i set up one of these things so i may be mistaken :-)
michaelikus Thu, 01/15/2009 - 03:51
allready done but no changes.
one more details.
i'm using ipsec on pix behind nat(my provider gived me address using pptp). so i set up the nat-traversal on pix. Maybe problem in it?
access-list wan_acl permit ip any any
access-list lan_acl permit ip any any
access-list lan_acl permit icmp any any
access-list t_ipsec permit ip
access-list t_nonat permit ip
global (outside) 1 interface
nat (inside) 0 access-list t_nonat
nat (inside) 1 0 0
access-group wan_acl in interface outside
access-group lan_acl in interface inside
route outside 1
route outside 1
crypto ipsec transform-set ts-1 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 3600
crypto map cm-1 21 ipsec-isakmp
crypto map cm-1 21 match address t_ipsec
crypto map cm-1 21 set peer
crypto map cm-1 21 set transform-set ts-1
crypto map cm-1 interface outside
isakmp enable outside
isakmp key ******** address netmask
isakmp identity address
isakmp nat-traversal 20
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
--end cut--
