ASA5520 SSH access
Jan 15th, 2009
Dear all
I am adding a new jump station to the network which is supposed to connect via ssh only to ASA.
using ASDM, I add teh host address of jumpstation under properties, device access, secure shell and apply. easy enough, but does not work...any suggestions ?
TIA
Sam
Overall Rating: 3 (1 ratings)
JORGE RODRIGUEZ Thu, 01/15/2009 - 04:41
Sam, I assume you have configured crypto keys for ssh access as this is required for ssh access to security applience. If you have done so on this part I would then believe something wrong in your ssh added statement rule.
asa(config)#ssh < mask>
make sure ssh statement for jumpstation is comming from correct nameif interface.
examples
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml
regards
cisco_lad2004 Thu, 01/15/2009 - 05:12
Thanks for the response !
I found out teh config was correct, but DNS was point at wrong FW interface. and therfeore requests are dropped.
Sam
