*Newbie* Site to Site vpn problem
Jan 15th, 2009
I am new to the world of VPN.
I have a 2811 connected via the net to a VPN conncentrator.
Good news is VPN is up and working, 'UP-ACTIVE'.
How do I check that the routing is working? in respect of my LAN packets being recieved by the VPN conncentrator once the VPN tunnels is up and working.
I have a route to the VPN peer - ip route x.x.x.16 255.255.255.255. f0/0
Another route to the remote network on the other side on VPN conncentrator -
ip address 172.16.0.0 255.255.255.0 x.x.x.16.
I have been told the static should have a next-hop of the peer. Is this correct?
How can I check when I try to ping a device it is being encrypted? and reaches the vpn conncentrator
marcelnjkoks Fri, 01/16/2009 - 03:47
Issue the command show crypto isakmp SA.
When the encrypt and decrypt counters increase, packet are encrypted.
You can also do a show ACL for the ACL you use to define traffic to encrypt. See if hits are increasing.
