01-15-2009 05:13 AM - edited 03-15-2019 05:05 AM
I have a question from my customer. They have a cisco 2821 with an NM-1CE1B module(PRI) and want to configure it as RAS for remote isdn users. Does the router need DSP/PVDM for this? As I am a voice guy I dont really know. I dont know if remote users are isdn or modems or a mix.
Any ideas.
Thansk
Mattias
Solved! Go to Solution.
01-15-2009 05:53 AM
Correct.
As a recognition to contributors, please rate useful posts using the scrollbox below.
01-15-2009 05:22 AM
The module alone supports data calls only, and in older router it was used together an NM-xDM to terminate modem calls. However the current technology of terminating modem calls on an ISR router is with a PVDM2-xDM module and HWIC-xCE1T1-PRI.
01-15-2009 05:31 AM
Thanks bevilacqua!
I guess then there is no need for DSP for ISDN data only.
01-15-2009 05:53 AM
Correct.
01-15-2009 05:55 AM
5 points!!!!!
01-15-2009 05:57 AM
Thank you for the nice rating and good luck!
