PIX - dropped VLAN untagged packets
Jan 15th, 2009
I am running version 7.0(7) on a PIX 515e. My question is I am seeing many dropped VLAN untagged packets. See output:
Interface Ethernet0 "outside", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address 001a.a2a4.7c96, MTU 1500
IP address 2X.X.X.X, subnet mask 255.255.X.X
1154270 packets input, 1384583104 bytes, 0 no buffer
Received 3818 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
748746 packets output, 516938253 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/14)
output queue (curr/max blocks): hardware (0/11) software (0/1)
Received 1620863 VLAN untagged packets, 1359047144 bytes
Transmitted 1268550 VLAN untagged packets, 491662091 bytes
Dropped 27314 VLAN untagged packets
What does this mean?
Jim
m.sir Thu, 01/15/2009 - 06:46
Do you have subinterfaces on that interface??? If yes might be that this interface will only accept tagged packets and untagged are dropped
M.
cdcjim2877 Thu, 01/15/2009 - 07:10
No; here is the physical breakdown.
"Cloud"
PIX 515e
Barracuda Content Filter (310)
2821 ISR
3560 - core switch (VLAN's)
VLAN's are only assigned and working on and below the 3560. The content filter shows no input errors or CRC's leading to the PIX.
