show commands not showing - ACE module.
Jan 15th, 2009
Hello
After a few days of working fine the systems stopped answering SNMP and then the CLI began having problems with some commands. The easiest to see being "show running-config". At this point it shows nothing. It just waits and does nothing. I have to hit Ctrl-C to bring back the prompt.
The applications being balanced are working fine but the management is not.
The resources were allocated this way:
resource-class ADMIN
limit-resource all minimum 6.00 maximum equal-to-min
resource-class CLA
limit-resource all minimum 46.00 maximum unlimited
resource-class MAS
limit-resource all minimum 24.00 maximum equal-to-min
resource-class OL
The version running is A2(1.3) and the same thing happened with an earlier release.
It's a HA scenario and the problem appeared so far only in the CLA context which was active on different modules and did the same on both. That was just a test to discard hardware problems.
One of the messages we saw was:
ACE-CER/Admin# show resource usage summary
Error: Called API timed out
We are unable to show resources, running-config, etc. for the active context CLA.
Do you have a suggestion? Is it healthy to allocate “unlimited” as the upper limit? Could this be the problem?
Thanks a lot.
Guido
Gilles Dufour Thu, 01/15/2009 - 09:51
Guido,
this is usually a problem when your config gets really big.
Is that the case ?
You should definitely open a service request with the TAC because we are currently tracking those kind of issues.
Gilles.
ggalteroo Thu, 01/15/2009 - 10:43
Gilles
If you mean a “get” for a probe, in this context I only have one and it's not that big. It goes like this:
request method get url http://www.3x.6x.com/diario/hoy/index.html
On the other hand, in a different context I have nine of these:
request method get url http://nap10.16x.int.6x.com/buscar/juguete
3x, 6x and 16x mean that amount of letters.
Are these long enough?
To your knowledge, is this condition going to spread further and disrupt production traffic?
So once you have reached this condition whether caused by "gets" or not, would you recommend opening a TAC case?
Thanks a lot!
Guido
lalvenka Fri, 02/06/2009 - 09:07
Hi Guido,
The problem "Error: Called API timed out" could also be due to the logging level set to 5 or 7. If yes, then please reduce the logging level to 3 and see if that resolves the issue
Lalitha
ggalteroo Fri, 02/06/2009 - 09:36
Hello Lalitha
I was advised by a TAC engineer to do exactly that among other things. It could be a combination of resource allocation and too much logging. He told me to set a level 4 for logging and to rearrange the resourses differently among contexts. At this point we are waiting to see what happens.
Thank you!
Guido
jteixido@bbandt.com Mon, 02/09/2009 - 06:42
What is the command to limit my syslog resources from taking too much resources?I would like to keep my syslog to level 6, without taking up all the resources.
Thank you,
John...
