Having VoIP QoS on the ASA and between VPN Client peers
Jan 15th, 2009
Hey All,
my situation isn't that complicated but I am wanting to know if these ACLs will work with what I'm trying to accomplish.
I currently have an ASA5510 handling VPN connections.
This is NOT a site-to-site VPN, but a Client VPN connection.
This is my goal. And correct me if some of this is unnecessary.
We have a few users with Nortel soft phones that can go home and use their VPN connection. The connection works fine and we are experiencing good feedback. I am worried that when we roll this out to over 100 people we are going to experience some issues. To take care of these issues I would like to implement QoS over the VPN Client connections.
Second, I would like for VPN-to-VPN clients to talk to each other.
Third, I would like for VPN-to-VPN clients to only have VoIP traffic go between them and not allow any sort of data traffic.
Here is what I have drafted up so far and most of it was stolen from this configuration: http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008080dfa7.shtml
VPN Clients get an IP address of 10.110.198.0/24
access-list Encrypt-VPN-to-LAN extended permit ip 10.110.198.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list Encrypt-VPN-to-LAN extended permit ip 10.0.0.0 255.0.0.0 10.110.198.0 255.255.255.0
access-list Allow-Outbound-Calls extended permit tcp 10.0.0.0 255.0.0.0 10.110.198.0 255.255.255.0 eq h323
access-list Allow-Outbound-Calls extended permit tcp 10.0.0.0 255.0.0.0 10.110.198.0 255.255.255.0 eq sip
access-list Allow-Outbound-Calls extended permit tcp 10.0.0.0 255.0.0.0 10.110.198.0 255.255.255.0 eq 2000
access-list Allow-Inbound-Calls extended permit tcp 10.110.198.0 255.255.255.0 10.0.0.0 255.0.0.0 eq h323
access-list Allow-Inbound-Calls extended permit tcp 10.110.198.0 255.255.255.0 10.0.0.0 255.0.0.0 eq sip
access-list Allow-Inbound-Calls extended permit tcp 10.110.198.0 255.255.255.0 10.0.0.0 255.0.0.0 eq 2000
access-group All-Inbound-calls in interface OUTSIDE
crypto ipsec transform-set VoIP-Encryption esp-des esp-md5-hmac
crypto map VoIPmap 10 match address Encrypt-VPN-to-LAN
crypto map VoIPmap 10 set transform-set VoIP-Encryption
crypto map VoIPmap interface OUTSIDE
class-map VoIP-OUT
match access-list Allow-Outbound-Calls
class-map VoIP-IN
match access-list Allow-Inbound-Calls
policy-map global_policy
class inspection_default
inspect h323 h225
inspect h323 ras
inspect skinny
inspect sip
policy-map VoicePolicy
class Voice-IN
class Voice-OUT
priority
service-policy VoicePolicy interface OUTSIDE
same-security-traffic permit intra-interface
access-list VPN-to-VPN-VoIP extended permit tcp 10.110.198.0 255.255.255.0 10.110.198.0 255.255.255.0 eq h323
access-list VPN-to-VPN-VoIP extended permit tcp 10.110.198.0 255.255.255.0 10.110.198.0 255.255.255.0 eq sip
access-list VPN-to-VPN-VoIP extended permit tcp 10.110.198.0 255.255.255.0 10.110.198.0 255.255.255.0 eq 2000
access-list VPN-to-VPN-VoIP extended deny ip 10.110.198.0 255.255.255.0 10.110.198.0 255.255.255.0
Thanks for any help
pjscott13 Wed, 03/10/2010 - 16:04
Did you ever find a solution to this? I am wanting to do the same.
Let me know if you did manage to resolve this and how you did. Thanks!
