01-15-2009 06:57 AM
I'm running LMS 3.1 with RME 4.2 and I unable to inventory a 6509 with redundant sup720-10G. I have tried increasing the snmp timeout, removing the device from DCR and RME, verified the credentials and SNMP strings on the device and in DCR. I am attaching the IC_Server.log file
Thanks for any help in advance!
Solved! Go to Solution.
01-15-2009 09:46 AM
This is CSCsv65621. A patch is available if you contact the TAC.
01-15-2009 09:46 AM
01-15-2009 10:13 AM
Thank you very much! I will contact them asap!
