ACS and Cat6509-E : command line impossible : dot1x mac-auth-bypass
Jan 15th, 2009
Hi, I'm using ACS with a servers connected on a Catalyst 6509-E
I want that the authentification use the Mac Address (Auth by Mac).
But the catalyst does'nt allow this Command Line : dot1x mac-auth-bypass
Is there any solution for this?
The IOS is : s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF15, RELEASE SOFTWARE (fc1)
And in the Supervisor engine is : s72033-adventerprisek9_wan-mz.122-18.SXF15.bin
The show version is in the attached file.
Best Regards.
Anonymous (not verified) Sat, 01/24/2009 - 12:11
This problem is resolved in software release 8.6(5). Refer the bug ID CSCsl47391
