Factory Default of 3750
Jan 15th, 2009
Hi all,
I configured Cisco 3750 with stack cable. So configuration got replicated to second switch. When i was asked to remove the second switch , I removed the stack cable and issue write erase command. It was sucess and my configuration was erased.But still i am having Gi2/0/1 rather Gi1/0/1.
What to do?
Many Thanks,
Rick Morris Thu, 01/15/2009 - 09:45
I assume you are no longer going to have these two stacked?
From what I understand from the post. You removed stack cable, wr erase second switch, did you reload it or power cycle it?
Just because you erase the config it does not reset it until you reload it.
