What should i buy
Jan 15th, 2009
What is the determining factor on a router resetting. My router keeps resetting due to the amount of connections around 600 - 800. I am a PC power user and run a Slingbox, webserver, I use VPN, I nearly max out my entire cable connection and have 10 users on the network. I was looking at the Cisco 800 series routers as a possible solution?
Mark Yeates Fri, 01/16/2009 - 12:52
Had no issues using bit torrent. It's a pretty good SOHO router.
Mark
