7940 lobby phone setup as two speed dials only
Jan 15th, 2009
We currently have Call manager 6.1 (linux based) with a Publsher and Subscriber sitting in our cluster.
I am attempting to set up a 7940 (2 button) phone in a lobby type area. I want only the two buttonson the phone to work as speed dials would, but I can't seem to setup a phone button template for a 7940 phone with only two speed dials and no real line presence. Does anyone know how to go about this? I would greatly appreciate any assistance.
Thanks in advance,
Overall Rating: 5 (2 ratings)
Rob Huffman Thu, 01/15/2009 - 10:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Larry,
Sadly, this will not be possible with a 7940 (or any 2 Button phone) The problem is that the phones needs dialtone to complete a Speeddial and this comes from Line 1. You will see (or you may have already) that when you go to create a new Button Template, that Line 1 is a must and is not configurable**
Button template for Cisco 7940,Cisco 7940 (2 buttons)
Button Template Name*
Button Feature Label
1 Line**
2 Speed Dial
* indicates required item
** this button's feature is not configurable
You would need an IP Phone like a 7960/7961/7965 to accomplish this request.
Hope this helps!
Rob
jonesl1 Thu, 01/15/2009 - 10:43
I was afraid I might hear this answer. Oh well! Thanks for replying Rob! I appreciate the help.
Paolo Bevilacqua Thu, 01/15/2009 - 10:45
  • Hall of Fame,
    Founding Member
Then what if he was to setup intercom/auto-call under the DN for line ? These are CME terms not sure how they are called in CM.
I don't even get the logic why with a six buttons phone it would be possible ?
Rob Huffman Thu, 01/15/2009 - 10:53
  • Hall of Fame,
    Founding Member
Hey Paolo,
Hope all is well my friend. You never responded to my welcome back last weekend ...so, welcome back!!
The reason this would be possible with a 6 button phone is that Line 1 would be a DN/Line and then 2-6 could be Speeddials "hard-coded" against the applicable Line buttons.
Hope this makes some sense buddy!
Rob
Paolo Bevilacqua Thu, 01/15/2009 - 11:19
  • Hall of Fame,
    Founding Member
All well Rob, thanks and happy to see you again :)
Yet I don't see how it would be different :)
Rob Huffman Fri, 01/16/2009 - 09:18
  • Hall of Fame,
    Founding Member
Hey Paolo,
Obviously I can't explain this too well :(
What Larry wanted was a 7940 that looked like this (2 - Hard-coded Speedial Buttons)
7940
Button 1 - Speeddial to xxxx
Button 2 - Speeddial to yyyy
**But in CUCM Button 1 has to be a Line/DN it cannot be anything else.
So what I was suggesting was that the only way to get this to work would be to use a 6 Button phone like a 7960;
7960
Button 1 - Line/DN
Button 2 - Speeddial to xxxx
Button 3 - Speeddial to yyyy
Hope this makes some sense!
Rob
Paolo Bevilacqua Fri, 01/16/2009 - 09:39
  • Hall of Fame,
    Founding Member
Yes but my point was that the OP doesn't want Button1 to be Line/DN at all, just speed-dials. He wanted the choice of using two buttons only, because that is the number of valid destination he can reach from that phone.
Kind of tricky despite apparent simplicity, as you then have to CSS to let the phone dial via speedbuttons only.
Rob Huffman Fri, 01/16/2009 - 10:55
  • Hall of Fame,
    Founding Member
Hi Paolo,
I understood what Larry was trying to do but wasn't thinking of any way to accomplish this using Speeddials. +5 points for tweaking my small brain onto how this could be done!
I just tried this in the lab to verify that this works :)
You can setup two DN's one for line 1 and one for line 2. Make sure the Device CSS is set to none and then follow the steps in the doc below to setup these two lines to "HotDial" to the required destinations.
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml#intro
Hope this helps!
Rob
Paolo Bevilacqua Fri, 01/16/2009 - 11:41
  • Hall of Fame,
    Founding Member
Exactly, that is what I was suggesting as autodial (a CME term), so it's you that deserve the rating not me!
