Tieing 2 key systems together with fxo/fxs and 1760 routers
Jan 15th, 2009
I need some programming help from someone good on voice. I've got two offices that I'm trying to tie the phone systems together with 2x Cisco 1760 routers each with 2x PVDM-256K-4 1 DSP Modules. I've got the layout below and am basically looking to do two things.
First, I would like ext. 210 from the first site to dial a co group “1” or directly access a “CO line” that is connected to the Cisco and get dial tone to be able to dial the directory number for a “CO line” with the same setup at the second site and have it able to be answered like a normal call and be transferred.
The second connection I would like is to have ext. 210 be able to dial locally to one of site 1's analog single line extensions and have the Ciscos make a connection through to site 2 and go off-hook on one of the analog single line extensions of site 2 in order to get a site 2 dial tone and be able to dial locally @ site 2 to any extension, or dial one of site 2's co groups or directory number for one of site 2's real CO lines and place a “local” call to the outside world from site 2's lines.
Obviously this process would all be reversed for site 2 accessing site 1. I've come across a couple of documents, like ID: 15405, and a section of a VoIP Configuration guide labeled OL-1070-01 and have some command structure available, but the concept of how it all takes place and should be configured is a little fuzzy.
Thank you,
Mark
Paolo Bevilacqua Thu, 01/15/2009 - 10:24
Hi, decide some prefix that you want them to use when dialing off-site, and use that as destination-pattern for voip DP. Same on remote router to a pots DP matching a port, or a set as trunk-group. One you familiarize yourself with DPs it become very easy. You can make all the ports to be like a pool using preference option under dp and "no huntstop".
sandman420 Thu, 01/15/2009 - 10:42
I understand the dial peers only enough to probably program the first of two tasks that I'm trying to complete. The second task was to have an extension from site 1 call another s/l ext. at site 1 that is hooked up to the cisco and have the cisco answer the port and connect through to another s/l ext. at site 2 connected again to the site 2 cisco and provide site 2 key system dial tone back to the calling extension at site 1. That is the one I'm more concerned about and am really needing the help on, because I don't understand the dial peers to that degree to be able to program the second task.
Can anyone help me with this?
Nicholas Matthews Thu, 01/15/2009 - 10:41
It's probably worth taking a look at this document:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Things to note:
If you explicitly match a number in a destination-pattern on a POTS dial peer, the number will be stripped. This can be altered with EITHER the 'no digit-strip' or tinkered with the 'forward-digits ' command.
You can put an incoming translation profile on pots dial peers for one side that prefixes the numbers with a certain digit, and set a destination pattern that starts with the prefix digit on the outgoing.
To do the translation, take a look at this document:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
hth,
nick
sandman420 Thu, 01/15/2009 - 10:46
Sorry, but I do not pay for a service contract, therefore can not look at whatever it is those links contain.
Nicholas Matthews Thu, 01/15/2009 - 10:49
Forgot to make them friendly :)
Quick note for anyone that cares - most links this can be converted by changing 'partner' to 'customer'.
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Things to note:
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
sandman420 Thu, 01/15/2009 - 12:09
I see the customer/partner change, but still no go.
This is what I receive:
Forbidden File or Application
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
sandman420 Thu, 01/15/2009 - 15:49
OK, let me simplify things. I think I'm putting way too much thought into it all. I've got site A and site B. Site A (currently for testing) has a single line extension from Site A's key system plugged into port 0 in fxo card in slot 2. Site A will have a patch from port 0 in fxs card in slot 3 to a CO line on the key system. Site B has the same setup. Both have fa 0/0 configured with IP addresses on the same network (just to simulate the connections - later I will actually move these to two separate internet feeds for more advanced testing).
Currently for testing I have disconnected the fxs patches to the phone systems and just have a regular analog phone plugged in. When my phone plugged into Site A goes off hook, I get dial-tone from the extension hooked up to Site B (which is the exact way I want it). When my analog phone is plugged into Site B (port 0 of fxs card in slot 3) and goes off hook, it will ring port 0 of fxs card in slot 3 of Site A. This I don't understand. If I can get both to behave like Site A, I'd be happy.
I need to know if this makes sense to anyone on how I want this to operate? Is it achievable?
Here's my base config on it (Site A first, then Site B):
version 12.4
hostname Simmering
boot-start-marker
boot-end-marker
enable secret 5 $1$F/AM$ige2qFh9lVD6uNubE.qm80
no aaa new-model
voice-card 2
voice-card 3
ip cef
interface FastEthernet0/0
ip address 192.168.254.30 255.255.255.0
speed auto
no ip http server
no ip http secure-server
control-plane
voice-port 2/0
connection plar opx 290
voice-port 2/1
connection plar opx 291
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 190
voice-port 3/1
connection plar 191
voice-port 3/2
voice-port 3/3
dial-peer voice 280 pots
destination-pattern 280
port 2/0
dial-peer voice 281 pots
destination-pattern 281
port 2/1
dial-peer voice 290 voip
destination-pattern 29
session target ipv4:192.168.254.40
dial-peer voice 180 pots
destination-pattern 180
port 3/0
dial-peer voice 181 pots
destination-pattern 181
port 3/1
dial-peer voice 190 voip
destination-pattern 19
line con 0
logging synchronous
line aux 0
line vty 0 4
password Corazon64789
logging synchronous
login
transport input telnet
end
SITE B:
version 12.4
hostname Sigma
boot-start-marker
boot-end-marker
enable secret 5 $1$1H58$6.VsVieyi4srcC7v4Lndv0
no aaa new-model
voice-card 2
voice-card 3
ip cef
ip address 192.168.254.40 255.255.255.0
speed auto
no ip http server
control-plane
voice-port 2/0
connection plar opx 280
voice-port 2/1
connection plar opx 281
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 180
voice-port 3/1
connection plar 181
voice-port 3/2
voice-port 3/3
dial-peer voice 290 pots
destination-pattern 290
port 3/0
dial-peer voice 291 pots
destination-pattern 291
port 3/1
dial-peer voice 280 voip
session target ipv4:192.168.254.30
dial-peer voice 190 pots
destination-pattern 190
port 2/0
dial-peer voice 191 pots
destination-pattern 191
port 2/1
dial-peer voice 180 voip
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login
end
sandman420 Tue, 01/20/2009 - 06:41
I'm still not making heads or tails of this. Anyone willing to help me out with the voice programming?
sandman420 Thu, 02/05/2009 - 11:19
I've finally got it. Here's what made it work for anyone trying to do the same:
SITE 1:
version 12.4
hostname SITE 1
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
speed auto
no shutdown
no ip http server
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 190
voice-port 3/1
connection plar 191
voice-port 3/2
voice-port 3/3
port 2/0
port 2/1
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
end
AND SITE 2:
version 12.4
hostname SITE 2
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
speed auto
no ip http server
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 180
voice-port 3/1
connection plar 181
voice-port 3/2
voice-port 3/3
port 2/0
port 2/1
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
end
Too bad I can't rate my own comment for answering my own question, LOL =)
