c2821 Maximum Number of Vlans encap. dot1q
Answered Question
Jan 15th, 2009
How many Vlans encapsulation dot1q does support an c2821 with 2 Gigabit Ethernet interfaces?
Thanks.
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Mariano,
in a router each Vlan subif takes a row in the IDB = interface descriptor block.
the total of physical and logical interfaces on your router cannot be higher then the IDB size.
This number is dependent on platform and IOS version.
on a c2821 the IDB can be 512
I didn't find the number so you should be able to implement several subinterfaces on your router.
2821
900
see
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml#idb_limits
I shouldn't go behind 20 subinterfaces per GE there are other factors to be considered like the size of the NIC MAC packet filter.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 01/15/2009 - 13:28
  • Hall of Fame,
    Founding Member
Hello Mariano,
2821
900
see
Hope to help
Giuseppe
