Common Partition Disk Space
Jan 15th, 2009
We use Unity Connection 2.1.1 I am trying to upgrade to 2.1.2 and get an error stating that the Common Partition does not have enough disk space to perform the upgrade. It says also to use the RTMT to free space in the partition. I have the RTMT open but do not know what do do in it to free up space in the partition.
Thank You in Advance~
bstremp Wed, 01/21/2009 - 07:58
Use a different upgrade method (such as SFTP or LOCAL) or use different FTP server software.
Mojo1 Wed, 01/21/2009 - 09:31
I have used the FTP Server software on Cisco upgrades before without a problem. I just wanted to know how free up disk space on the common partition so I can upload the upgrade file.
iptuser55 Thu, 01/22/2009 - 01:05
  • Silver, 250 points or more
I`m doing a upgrade in CUCM and have the same issue though in RTMT is shows there is enough free. Did anyone work how to delete teh memory? thanks
aurelien piaszc... Fri, 01/29/2010 - 01:48
Hi there,
I have this problem on a CUCM 7.0.2. I can't upgrade it to 7.1.3 because of  insufficant space on the common partition. I deleted many logs with RTMT but only managed to gain 3% of space. The common partition is 22Go in size, used at 87%  and the CUCM is only used for integration tests purposes.
Is there other files than logs I can get rid of?
Many Thanks
Aurelien
