Device license unit file
Answered Question
Jan 15th, 2009
Does any of you have the link to get the file where is show all the license unit asign to each type of IP phone/Device
I have one excel file but is not included 7921 IP phone.
Correct Answer by Rob Huffman about 8 years 4 months ago
Hi Filiberto,
Just to add a note to the good (correct) tips from Joel, I have attached a newer version of the DLU Calculator that includes models like the 7921.
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Thu, 01/15/2009 - 17:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Filiberto,
Hope this helps!
Rob
Sushil Kumar Katre Thu, 01/15/2009 - 20:27
  • Gold, 750 points or more
Hey Rob Excellent Info (+5).
I also use the same file and was wondering if you observed this - (sorry for going out of track)
1) ATA 186 - DLUs required for 5.0(4a) is 2, for 5.1 its 3 and for 6.0 & 6.1 its 1.
Is this really true since I guess with CUCM 6.X it still requires 2 DLUs.
2) Mobility Enabled End Users - for 6.0 2DLUs, for 6.1 4DLUs.
There is a confusion again because Mobility still requires only 2 DLUs if I am not mistaken.
3) Mobility Enabled End Users (Adjunct) - 6.1 requires 2 DLUs.
I guess its 1.
What's your take on this.
BTW just observed Spell Check is now incorporated while typing the posts.
-> Sushil
filiberto.aguirre Thu, 01/15/2009 - 20:55
thanks Rob,
very helpful file,
I hope cisco publish soon this file including CM version 7
