VPN3030 & LMS 4.1.1
Jan 15th, 2009
I am trying to inventory & archive a VPN Concentrator 3030. I am able to get the inventory piece to work, however, the archive is failing. CW reports the following:
*** Device Details for VPNC3030 ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> TFTP,SSH,Telnet
Execution Result:
RUNNING
CM0151 PRIMARY RUNNING Config fetch failed for VPNC3030 Cause: TFTP Protocol not supported for VPN3000
SSH Protocol not supported for VPN3000
TELNET Protocol not supported for VPN3000
Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.
Does anyone have any info about how to successfully archive the VPN 3030 config with RME 4.1.1?
Thank you.
Joe Clarke Thu, 01/15/2009 - 14:07
You need to add HTTPS to your transport settings for the VPN concentrators under RME > Admin > Config Mgmt > Transport Settings.
drew.salmon Fri, 01/16/2009 - 05:56
Joe, as always, thank you very much for your help. That fixed my issue. I was able to get the device config to archive.
