Call Manager & dial peer.
Jan 15th, 2009
If we want to make calls to PSTN,at route pattern we will at Gateway/Route list the ip address of the gateway that connected to PSTN, then at gateway we will make dial peer to transfer the call to port that connected to PSTN, Is this right procedure?
virverma Thu, 01/15/2009 - 20:55
  • Silver, 250 points or more
Yes, this is correct if you following mgco then call control is at call manager.
Make sure you design RP carefully.
titomontos Fri, 01/16/2009 - 04:51
Sorry virverma what is the meaning of RP?
Thanks all.
mparra.fusionet Fri, 01/16/2009 - 07:43
He was referring to the "Route Pattern" on CallManager, just to make sure that the call gets sent correctly from CCM to the Voice gateway, from there the gateway should route the call to a port as you correctly stated above by using dial peers.
virverma Fri, 01/16/2009 - 09:11
Oh my mistake,
its route pattern
titomontos Fri, 01/16/2009 - 13:27
Thanks mparra and thanks virverma,
Question to Mr.mparra you said that"from there the gateway should route the call to a port as you correctly stated above by using dial peers."
is this at H323 only or at MGCP also ?
mparra.fusionet Fri, 01/16/2009 - 17:38
Hello titomontos,
That is on H.323 only, with MGCP the call routing intelligence is handled by CCM, so in summary dial-peers are not needed to route calls with MGCP.
Please don't call me mparra I'm too young for that yet :)
Take care!
