EIGRP and NAT
Jan 15th, 2009
Hello everybody
It is my first time writing here and I would like to thank you for spending your time on my question.
So,I am a CCNA candidate and I came up with a problem.I connected back to back two cisco routers (2610XM using the low speed serial int and 2600 using the serial and providind the clocking at 64000).The problem is that if I have nat configured,EIGRP is not working and when I use debug it shows that one router is finding the other but after a while looses the adjajency.At the show ip route, I am getting no EIGRP routes.If I use OSPF everything's working.No auto-summary is configured fo EIGRP.If I disable nat,EIGRP is working fine.Any ideas what could be the problem?
lejoe.thomas Thu, 01/15/2009 - 17:53
Hi Emmanouel,
It would be helpful if you could post the running-configuration when EIGRP is configured.
Lejoe
Giuseppe Larosa Fri, 01/16/2009 - 05:43
Hello Emmanouel,
in a real world scenario a dynamic routing protocol is not used at a NAT device interface that is usually at a border router.
you can make EIGRP working by changing NAT configuration so that you can use an extended ACL.
access-list 101 deny eigrp any any
access-list 101 permit ip net wildcard any
route-map sel-nat
match ip address 101
ip nat inside source route-map sel-nat ...
What I don't understand is how OSPF works with NAT enabled.
Hope to help
Giuseppe
