non-designated port in stp
Answered Question
Jan 15th, 2009
  • Bronze, 100 points or more
hi every body!
What is non-designated port in stp? Is it root port and blocked port or only blocked port? Some cisco docs refer it as root port and blocked port while others refer to it as only blocked port.
thanks a lot!
Correct Answer by Francois Tallet about 8 years 4 months ago
Hi Sarah,
Well, both;-)
Every port that is not designated is... non-designated. You are probably hitting some inconsistencies in the docs.
Francois
Overall Rating: 5 (1 ratings)
Correct Answer
Francois Tallet Thu, 01/15/2009 - 16:00
  • Gold, 750 points or more
Hi Sarah,
Well, both;-)
Francois
