LAN, Switching and Routing Configurations
I have the configuration issue of trunk links between 6509 and 3650 switches. When I configure the trunks links with transparent mode on the both switches, The 3650 switch can only see the 6509. If I configure using the EIGRP as a layer 3, it works. However, each time when some VLANs are up and down, the trunk link is also down and up for very short period of time. Any suggestions I should look into this? Thanks
