MPE hostname changed
Jan 15th, 2009
Hi All,
I have changed hostname and domain name for eth0 port. everything works fine except I can't access to MPE through outlook. I have uninstalled outlook plug-in, reinstalled it, changed URL in MPE admin page and restart MPE but still when I press Meetingplace tab in outlook calendar, it says " URL is not correct".
any suggestion would be very appreciated.
thanks
Alex
Ginger Dillon Fri, 01/16/2009 - 08:14
Hi Alex -
From Outlook, go to Tools - Options. Select the MeetingPlace tab. In the Servers: field, select the url name of the server. You can change it by highlighting the server name in the field and then click Edit. Adjust the Server url in the field and reply OK. Then Reply OK a second time to Save and close the Options window.
Ginger
alex goshtaei Fri, 01/16/2009 - 08:41
Hi Ginger,
I did that, and URL in outlook is matched to URL in MPE. when I changed hostname and domain name, I changed URL in MPE as well. but still it doesn't work.
any suggestion
thanks
Alex
