Error message during setup second node for CUCM7.0.1
htluo Thu, 01/15/2009 - 18:53
The message explained itself - not able to sync with NTP.
The best practice is NOT to use NTP/DNS/SMTP during install. You'll have the chance to configure those after install.
htluo Thu, 01/15/2009 - 19:47
sorry, didn't notice that you were installing 2nd node.
You'll have to wait until the 1st node synchronize up with NTP before installing 2nd node. If 1st node didn't sync to NTP, 2nd node won't sync to 1st node.
Workarounds:
1) Find out why 1st node didn't sync up to NTP.
or
2) Delete NTP server from 1st node.
My blog:
http://htluo.blogspot.com/
Hi, Mr. Luo
I can see the 1st node did sync up with NTP server 10.15.15.2
admin:utils ntp status
ntpd (pid 5505) is running...
remote refid st t when poll reach delay offset jitter
127.127.1.0 LOCAL(0) 10 l 11 64 377 0.000 0.000 0.004
*10.15.15.2 128.250.36.2 2 u 267 1024 377 1.949 6.925 2.740
synchronised to NTP server (10.15.15.2) at stratum 3
time correct to within 78 ms
polling server every 1024 s
Current time in UTC is : Sun Jan 18 19:05:11 UTC 2009
Current time in Pacific/Auckland is : Mon Jan 19 08:05:11 NZDT 2009
admin:
rob.huffman Sun, 01/18/2009 - 11:23
Hi Kevin,
The second reference in the attached screen capture is asking about whether or not the second node was added to the Pub/1st node (server list) before starting to build.
Just checking,
Rob
