SupE in Slot 4 does not show in inventory of 4507 E
Answered Question
Jan 15th, 2009
Hi - (pardon the ignorance)
I believe this is a config issue. Since I basically unpacked everything mounted the chassis and inserted the cards. In an essence no config.
Anyhow, I notice amber light on the sup engine in slot 4.
No matter what I do, the redundant supervisor will not come active. It does not show up when you run "show inventory". I know the switch thinks it is present, because it shows both supervisors' TenGig interfaces. I had pulled the redundant Sup out hot, then plug it back in. There are log messages that show it being removed and show it being reinserted, but it does not show up in show inv.
I then swap the 2 Sups. The one that was the active in slot 3 previously became the active in slot 4, and the redundant Sup still would not show up. This at least proved that all of the slots are good. When I plugged the console into the redundant Sup, I get the prompt "rommon>" instead of "switch>".
I don't know if any of this is normal behavior. I did see on the switch that the Sup shows up in show inv. I dont possess deep knowledge of dual sup but perhaps redundancy sso needs to be configured?
The switch is new the chassis is 4507 E
the sups are WS-X45-SUP6-E
The rest of the slots are filled with the following: WS-X4648-RJ45V+E
and (1) WS-X4306-GB
Correct Answer by glen.grant about 8 years 3 months ago
Sounds like the 2nd sup is not booting , console in and issue "boot bootflash: command and see if the sup will boot . Once up verify the config register and software versions are the same.
Overall Rating: 4.4 (5 ratings)
Mark Yeates Thu, 01/15/2009 - 19:18
  • Gold, 750 points or more
I noticed you said you have an amber light on the supervisor in slot 4. The supervisor(s) must reside in slots one and two. Try installing them in slots 1 & 2. To configure SSO here are the commands:
redundancy
mode sso
Also here is a guide that will help you configure SSO.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sg/configuration/guide/NSFwSSO.html#wp1131609
HTH,
Mark
Mark Yeates Fri, 01/16/2009 - 12:53
Sorry about that. I missed the E part of the chassis. Can you post the output of "show module" and "show redundancy"?
Mark
planzone Fri, 01/16/2009 - 12:59
Sure thing mark:
Switch#sh module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 6 1000BaseX (GBIC) WS-X4306-GB JAE1240WFP9
2 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE1241WX5B
3 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE12470NJB
4 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E JAE12470O70
5 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE1241WYZT
6 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE1241WX4T
7 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE1239VL6I
M MAC addresses Hw Fw Sw Status
1 0016.c76f.9dbc to 0016.c76f.9dc1 4.4 Ok
2 0023.04e4.b4c0 to 0023.04e4.b4ef 1.2 Ok
3 0021.a077.bf40 to 0021.a077.bf45 1.2 12.2(44r)SG 12.2(40)SG Ok
4 0021.a077.bf46 to 0021.a077.bf4b 1.2 12.2(44r)SG 12.2(40)SG Ok
5 0021.5597.cc80 to 0021.5597.ccaf 1.2 Ok
6 0023.04e4.afe0 to 0023.04e4.b00f 1.2 Ok
7 0023.04e4.9b10 to 0023.04e4.9b3f 1.2 Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor RPR Active
4 Standby Supervisor RPR Standby cold
Switch#
And here is the redundancy:
Switch#sh redundancy
Redundant System Information :
Available system uptime = 5 hours, 29 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = RPR
Operating Redundancy Mode = RPR
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 3
Current Software state = ACTIVE
Uptime in current state = 5 hours, 28 minutes
Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 19:52 by prod_rel_team
BOOT = bootflash:cat4500e-ipbase-mz.122-40.SG.bin,1;
Configuration register = 0x2101
Peer Processor Information :
Standby Location = slot 4
Current Software state = STANDBY COLD
Uptime in current state = 4 hours, 51 minutes
Switch#
planzone Fri, 01/16/2009 - 15:09
Ugg for real?? Well at least the core is not live.
BTW I have the two sups up and running now but to your point I may have to perform the ios upgrade cause I no sso option.
"grinding teeth"
planzone Sat, 01/17/2009 - 07:12
Thanks Mark. Since I have (2) sups I have to obviously perform this on both?
And another thing. All these different version of ios to d/l. example with crypto
or enterprise. uggh gets confusing.
Mark Yeates Sat, 01/17/2009 - 10:56
Correct. Both supervisors will need to be upgraded. In your earlier post it shows that you are using IP base (non crypto). I would stick with that.
Mark
planzone Sat, 01/17/2009 - 11:11
Thanks Mark! I appreciate your replies.
I will give it a whirl this week. What's nice is that those supervisors have USB ports on the front. So i can take advantage up those ports to xfer the flash.
planzone Sat, 01/17/2009 - 11:56
Or make it easier I can use the Cisco Network Assistant to upgrade this.
planzone Fri, 01/16/2009 - 08:41
I also wanted to add that when I type mode ? at the config-red prompt only the rpr option is shown no sso
any hints or tips..
Correct Answer
glen.grant Fri, 01/16/2009 - 08:41
  • Purple, 4500 points or more
planzone Fri, 01/16/2009 - 10:59
I did.
Was able to boot like you said and the versions are the 12.2(40)SG.
what I have found that would happen now is if i type reload then one of the sups will come up in rommon again..
also when configuring for redundancy there is no SSO just rpr.
any other hints or tips.. ??
glen.grant Fri, 01/16/2009 - 12:57
Look at the config register on the one that not coming up , should be either 0x2101 or 0x2102 . Or you can match it to what the supervisor that is loading ok is which is probably one of those 2 .
aminhaq Mon, 01/19/2009 - 09:22
Please try to to upgrade the IOS to 12.2(44)SG or above for both the Sup.
I have observed the E-chassis does not work well with the lower IOS
