SSH
Jan 15th, 2009
guys in out company we are config ssh on out routers and swithes but requirmnet is that it shd support both version (1 and 2) i know how to enable ssh but is there any specific comand to enable these both ??? can someone help me plz
Overall Rating: 3.5 (2 ratings)
royalblues Fri, 01/16/2009 - 00:30
  • Green, 3000 points or more
No you can enable either of the versions but not both
Why is it a requirement to support both versions? If your devices support SSHv2, i would recommend configuring v2 while the non supporting ones can be left at v1
Narayan
redrobish Wed, 01/28/2009 - 20:27
since this is regarding ssh, i have this cisco 2801 that i wanted to enable ssh. however i cannot enter commands such as "cry key generate rsa" and "ip ssh ..". Don't know y? they are unrecognized commands!
IOS 12.4(20)T1.
any hints y?
thnx
Mark Yeates Wed, 01/28/2009 - 20:36
  • Gold, 750 points or more
It appears that you don't have a crypto version IOS. You will need to download a crypto IOS, and upgrade the IOS.
HTH,
Mark
redrobish Wed, 01/28/2009 - 21:28
I was about to answer my issue since i just found out in the release notes...but you're too fast. So i'll rate you for that.
thnx
Richard Burts Thu, 01/29/2009 - 05:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Robert
Since Mark did correctly analyze your problem and suggest the correct solution, I am surprised that you rated his as a 2. I think that he deserves better and I will give him better.
Rick
Mark Yeates Thu, 01/29/2009 - 15:50
Thanks Rick!
I appreciate the support,
Mark
