don't use auto generated MAC address
Jan 15th, 2009
How can i configure the multiple context ASA with don't using the auto generated MAC address.
I do not want to use 'MAC address auto"
cmd.
swami
smalkeric Wed, 01/21/2009 - 12:51
  • Silver, 250 points or more
To manually assign a MAC address to this interface, on the Advanced tab enter a MAC address in the Active Mac Address field in H.H.H format, where H is a 16-bit hexadecimal digit. For example, the MAC address 00-0C-F1-42-4C-DE would be entered as 000C.F142.4CDE.
If you share an interface between contexts, you can assign a unique MAC address to the interface in each context. This feature lets the security appliance easily classify packets into the appropriate context. Using a shared interface without unique MAC addresses is possible, but has some limitations.
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/contexts.html#wpxref64049
http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/ifcmulti.html#wp1055358
