6509 PC Card format failed in slot0
Answered Question
Jan 16th, 2009
I might need to format or delete file into the PC Cards in 6509 slot0, but I can't do it.
I changed the PC Cards with a New and I've the same thing.
Anything suggestion ?
Correct Answer by Mark Yeates about 8 years 6 months ago
You may have a faulty card and may need to be replaced. Which supervisor and software version are you running? Also check this field notice and see if it applies to you.
http://www.cisco.com/en/US/ts/fn/620/fn62466.html
Mark
Overall Rating: 5 (1 ratings)
Mark Yeates Sat, 01/17/2009 - 12:48
  • Gold, 750 points or more
Which CF card are you using? Have you tried formatting in another slot or supervisor?
michelerossi Mon, 01/19/2009 - 06:12
Yes, but I can't do It, because I obtain the same result.
I used a "MEM-C64K-ATA-1-64M" memory card.
Is it correct ?
michelerossi Tue, 01/27/2009 - 08:45
I've a Sup1a and It doesn't support the ATA PC CARD.
Best reguard
Leo Laohoo Sun, 01/18/2009 - 13:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I think it will only accept UP TO 2Gig Type III CF cards.
