route-map and 'ip policy'command
Answered Question
Jan 16th, 2009
Please can any one explain in brief when I need to apply the 'ip policy route-map' command at the interface when doing route-map.
Is it when I am using it for redistribution or packet redirection. Or both.
Correct Answer by Sushil Kumar Katre about 8 years 6 months ago
Hi Kennie,
As pointed by Lejoe "ip policy route-map" is the command used with respect to Policy Based Routing.
PBR has two configuration parts - Creating Policy and applying the policy on the interface.
You create policy using "route-map name" command and apply it on an interface using "ip policy route-map name" command
interface fa 0/0
ip policy route-map xyz
route-map xyz
match ip address 10.10.10.12
set ip next-hop 11.11.11.12
PBR is always matched for inbound traffic on an interface.
Overall Rating: 5 (1 ratings)
Correct Answer
Sushil Kumar Katre Fri, 01/16/2009 - 02:20
  • Gold, 750 points or more
Hi Kennie,
interface fa 0/0
route-map xyz
