cisco 1841
Jan 16th, 2009
i thank you so much for all the help rendered.
now i would like you to help me with a net work diagram of how to connect the cisco router 1841. i want the connection from the 2.4m antenna to the BUC, LNB back to the modem then to the 1841 series and finally to the switch.
Do you have to configure the equipment while in operation or you can configure while getting ready to start operation of the equipment.
thank you so much
