Multicast setup 4507R & 3750 Access
Jan 16th, 2009
Im trying to enable multicasting on our network for ghosting.
We are using a 4507R as our router and 3750 for our access switches.
I have enabled IP multicast-routing and ip pim sparse-dense-mode on the affected VLAN interface's on the 4507.
I havent changed the default multicast settings on the 3750's
Ghostcast will not work and I presume I have not properly configure multicast routing.
the 3750's are running the base IP IOS
how should I best configure my hardware to enable multicasting.
Kind regards
G
Overall Rating: 3 (1 ratings)
austin0824 Fri, 01/16/2009 - 03:12
Hi G,
You are running IP Base feature set. You will have to upgrade to the Advanced Feature set...c3750-advipservicesk9-tar.122-40.SE.tar
garethmitchell Fri, 01/16/2009 - 03:33
Hi Austin,
Thanks, I was hoping there would be an alternative as its going to take me a while to update all the switches.
Is there any assosiated cost with upgrading the IOS to advancedIP? (also thanks for taking the time to find the filename)
presumably I will then just need to follow the instructions on setting up basic multicasting as outlined in chapter 44 of the 3750 config guide :)
Kind regards Gareth
Giuseppe Larosa Fri, 01/16/2009 - 03:40
  • Hall of Fame,
    Founding Member
Hello Gareth,
if the C3750 at access layer are used as L2 switches you just need to enable IGMP snooping.
So the question could be is IGMP snooping supported in IP base code ?
this should be in ip base code
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swigmp.html
Hope to help
Giuseppe
Jon Marshall Fri, 01/16/2009 - 03:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Giuseppe / Gareth
Funnily enough i was just about to write the same thing !. If all the inter-vlan routing is done on the 4507 then as you say you just need IGMP snooping. I just checked Feature Navigator and IGMP snooping is supported in IP Base.
Jon
garethmitchell Fri, 01/16/2009 - 05:35
Ok, thats great news but Im afraid I dont understand what commands I should be using to enable snooping or on which interfaces?
Do I need to change any settings for the uplink interface or just for the VLAN or both? and should snooping be enabled on the 4507?
sorry for being so hopeless and thank you all for your time
Giuseppe Larosa Fri, 01/16/2009 - 06:00
  • Hall of Fame,
    Founding Member
Hello Gareth,
you need to enable ip igmp snooping only on the C3750.
you just need
config t
ip igmp snooping vlan
or simply
ip igmp snooping
to enable on all vlans
the 4507 will provide the IGMP querier and PIM DR roles
igmp snooping allows the L2 switch to optimize multicast forwarding by listening to IGMP messages from router and end users.
instead of sending the multicast stream out all ports of vlan 5 it builds a L2 list of ports of vlan 5 that have to receive the traffic and filters it out other ports of same vlan5.
if there is an interested receiver out a port the switch intercepts the PC IGMP report for the group.
Hope to help
Giuseppe
garethmitchell Fri, 01/16/2009 - 06:11
Hi Giuseppe,
ok that makes more sense to me now thanks, but ive check the snooping on the 3750 and its enabled (I think this might be default?) on all VLAN's but im still not having any Joy with the ghost casting.
Is it possible there is something wrong with the setup on the 4507? what should I check?
Many thanks
Gareth
Giuseppe Larosa Fri, 01/16/2009 - 06:48
  • Hall of Fame,
    Founding Member
Hello Gareth,
you need to enable multicast routing
ip multicast-routing
then on each Vlan including the source vlan (where the ghost server is connected) you need
int vlan X
you should be fine in this way even without setting an RP.
Hope to help
Giuseppe
Jon Marshall Fri, 01/16/2009 - 07:14
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Gareth
In addition to Giuseppe's post you also need to make sure that the Ghost application is setting the TTL in the packets to > 1. If all vlans are routed off your 4500 then a value of 2 would be fine.
Ghost by default uses a TTL of 1 i believe and this means it won't route between the vlans.
Jon
garethmitchell Mon, 01/19/2009 - 06:31
Hi Jon,
Thanks for joining in, yes I believe all the IGMP packets coming from ghost are set with a TTL of 1 and I do not know of any way to change this.
This chap Nigel Bree an apparent employee at symantec has something to say on the matter although his comments on RFC 2236 do not seem to agree with the document as I read it.
https://forums.symantec.com/syment/board/message?board.id=109&message.id=5809
Is there any other way to stop the packets from being discarded before reaching the router?
Gareth
Giuseppe Larosa Mon, 01/19/2009 - 07:31
  • Hall of Fame,
    Founding Member
Hello Gareth,
routers cannot modify the TTL field with an increment they can only modify it with a decrement.
You need to find a way to increase TTL at the application level or you need to revert to unicast and to use
ip helper-address to convert a broadcast request to a routable unicast packet towards the server.
other forms of helper addresses exist for example
ip multicast helper-map
see
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1033212
but this converts a broadcast to a multicast.
Hope to help
Giuseppe
Jon Marshall Mon, 01/19/2009 - 11:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Gareth
There is some confusion here. That thread is talking about increasing the TTL on IGMP packets. Quite rightly the thread states that you wouldn't want to do this because IGMP is local to the subnet.
What i am talking about is not increasing the TTL of the IGMP packets but the TTL of the multicast data traffic which is something completely different. The Ghost application sends out multicast packets (nothing to do with IGMP) and for these packets to traverse a routed interface they must have a TTL > 1.
So somewhere within the Ghost application there will be a checkbox or setting to increase the TTL on the multicast packets. If there wasn't Ghost would be a pretty useless application.
Edit - had a further search on symantec forums. Looks like Ghost uses a TTL of 16 by default which is more than enough altho some people reported problems and it looks like it can be overriden by the OS at times. If you could capture one of the multicast packets with Wireshark you would know for sure.
Jon
