Dial-out script for AS5350
Jan 16th, 2009
I have AS5350 with 2 PRI cards. It is used as modem pool for dial-out. I need to accomplish following task: An application must be able to use AS5350 to call a telephone number, enter some code using DTMF an then hangup the line.
I have tried to accomplish this using telnet connection and issuing AT commands, but for some reasons the modem behaves unpredictable and hangs often.
Is it possible to accomplish my task using TCL script?
Thank you!
Paolo Bevilacqua Fri, 01/16/2009 - 13:46
Do you have voice DSP in the AS? If so you can use TCL/IVR to dial and send the digits.
