Errors in Controller interface ( SLIPs and Errors ).
Jan 16th, 2009
Hi ,
We are facing the below given errors at the controller .
It has been configured as PRI EURO ( MGCP ) .
We have done the reset for the same . But still we are facing as errors are keep on increasing .
# sh controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (542 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
34 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
34 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 16 15 minute intervals):
1 Line Code Violations, 0 Path Code Violations,
893 Slip Secs, 1 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
893 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 371 Unavail Secs
Can any one helpout from this issue ?
Regards ,
sinjish.K
Nicholas Matthews Fri, 01/16/2009 - 04:32
  • Red, 2250 points or more
Please try this command:
network-clock-select 1 e1 0/0/0
Then:
Router#clear counters
There's a good chance you're missing this command.
hth,
nick
