Re-certification Advice
Jan 16th, 2009
All my CCNA & CCNP has been expired 3 years ago.
Can I take CCIE R&S written to renew all my CCNA & CCNP or do I have t re-take them again.
stephenneville Fri, 01/16/2009 - 03:29
You have to take them all again. Once they expire thats it you have no grace period.
dnyan.gujar Fri, 01/16/2009 - 03:33
Hi Nishit,
You can take the CCIE R&S. But it won't renew your CCNA & CCNP exams. As your Cisco ID is expired.
You can login to cisco & check it out by yourself.
Thanks.
Bye
Dnyanesh
antonio.pena Sat, 01/17/2009 - 09:10
Sorry I'm in similar situation, both my CCNA and CCNP expired, but just want to know if I can take again the CCNP without renewing my CCNA.
Also you mentioned the other colleague that he can check the status by itself, I have a valid CCO user but not able to check the status, can you tell me how?
scottmac Sun, 01/18/2009 - 06:51
You can take the CCNP tests (and/or any other tests)and pass, but you won't receive certification until you pass CCNA again.
Current CCNA is a pre-requisite. Once the cert expires, it's as if you never had it.
I wish Cisco would get off their duff and fix the verbiage of that information. You must be CURRENT to be re-certified. Expired certs cannot be re-certified (some grace time is given to CCIE).
Good Luck
Scott
