asa 5520 management port fuctionlity
Jan 16th, 2009
hi ,all
pls help me to understand the management port in asa 5520
can configured the management port as a normal port?
how can i use it as a management port?i mean how can i manage asa device using management port eg route,natting
JORGE RODRIGUEZ Fri, 01/16/2009 - 04:26
  • Green, 3000 points or more
You can have management0/0 as a dedicated management port, when you have management-only enabled only certain traffic pertaining to management goes through that port, you can disable it using the no management-only command and use that port as any regular router port in any of the asa5510 or higer models.
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/m.html#wp1973887
