Hreap restrictions and limits
Jan 16th, 2009
Is there any structural limit in the deployment of an hreap solution?
I mean if there is some limitation in the number of hreap ap's/sites on 440x controllers, a minimum requirement for wan bandwidth/delay and so on.
I think it's particularly interesting to know how much control bandwitdth needs to be reserved on the wan link for each remote ap.
Tnx,
Max.
Massimo Baschieri Fri, 01/16/2009 - 07:45
Many thanks, very nice doc, I should have found it by myself :-(
However it doesn't advice about bandwidth requirements of the lwapp control protocol, maybe it's so tiny that doesn't deserve a mention, anyone knows?
Tnx,
Max.
Rob Huffman Fri, 01/16/2009 - 08:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Max,
You are most welcome my friend! Here is some related info;
For HREAP's connected to a centralized wireless LAN controller, the WAN link must support a minimum speed of 128-kbps WAN throughput and 100-ms maximum roundtrip latency between each HREAP and the wireless LAN controller.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/prod_white_paper0900aecd804f1a23_ns337_Networking_Solutions_White_Paper.html
Hope this helps!
Rob
Massimo Baschieri Fri, 01/16/2009 - 09:44
Hi Rob,
as usual you are aware of docs I even cannot find by myself, I feel like a broken shoe :-)
128k for each hreap is a lot of bandwitdh, in fact it limits the number of hreaps to a very few each remote site.
Anyway, tnx a lot.
Bye,
Max.
Rob Huffman Fri, 01/16/2009 - 11:03
  • Hall of Fame,
    Founding Member
Hey Max,
Don't feel alone here my friend :) Finding docs here sometimes is like finding the proverbial "needle in a Haystack"!
Cheers!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
