Cannot hear on branch office calls
Our DR Site which is connected to our HQ and we have 100 Cisco IP 7941 phones. If a call coming into head office and ring on the phones in our DR Site, we can hear the customer and they can hear us. However, when a call comes into the DR Site from a branch office, the customer can hear us but we cannot hear them.
Any ideas anyone?
Anthony.
Hello Anthony,
your last post confirms you have missing routing information :
there is a default static route but is not useful to reach the DR site VOIP subnet.
just one question:
the BGP config is from branch or from HQ ?
if it is from HQ you need to look at
neighbor 10.1.1.202 distribute-list 4 out
and
neighbor 159.144.72.57 distribute-list 8 out
be aware that you may need to update two ACLs:
the one used outbound on HQ router
the one used inbound on branch router
I see you have an eBGP session with service provider router and an iBGP session with a router this makes the scenario a little more complex.
And yes you can perform additive (only additive changes ) to ACL on the fly as explained on one of previous posts.
probably adding the line to acl 8 where you see all the other VOIP subnets is a good move.
Hope to help
Giuseppe
19 Replies 19
Giuseppe Larosa
Hello Anthony,
what type of DR design have you deployed ?
Has the DR a totally distinct ip address plan ?
how is managed routing ?
have branch site a distinct link to the DR site ?
you may be facing asymmetric routing issue with some firewall somewhere seeing only one direction of flow and dropping it.
Hope to help
Giuseppe
Hi Guiseppe.
All phones in the DR site have a 10.180.x.x address as they are in VLAN800.
The configuration of the VLAN is as follows:
interface Vlan800
description DR SANTRY VOICE VLAN
ip address 10.180.x.x x.x.x.x
ip helper-address 10.1.8.x (ip address of switch in DR site.
ip pim sparse-dense-mode
end
The route is injected into BGP in our HQ. Extract from a router in our DR Site.
*>i10.180.x.x/16 x.x.x.x 2 100 0 ?
This route doesn't inject into the branch office routers bgp routing table. Am I barking up the wrong tree here, would this be why we cannot hear the customer from the branch office.
Our DR Site has a leased line which terminates at one of our Datacentres into a 6500 router. The phone register with the CM in our HQ.
I hope I have answers all your questions.
Thanks a million for your help.
Anthony.
Hello Anthony,
if the branch router doesn't receive a default route over the BGP session this is a problem.
call signalling happens with the call manager that is in the central site but the bearer stream RTP has to be able to reach the phone in DR site.
The call manager is probably able to have good connectivity with both so call setup is successful.
Hope to help
Giuseppe
Hi Guiseppe,
access-list 8 permit 10.10.0.0 0.0.255.255
access-list 8 permit 10.105.0.0 0.0.255.255
access-list 8 permit 10.125.0.0 0.0.255.255
access-list 8 permit 192.168.0.0 0.0.0.255
access-list 8 permit 10.10.1.0 0.0.0.255
access-list 8 permit 10.150.0.0 0.0.255.255
access-list 8 permit 192.168.10.0 0.0.0.255
access-list 8 permit 10.1.0.0 0.0.255.255
access-list 8 permit 10.131.0.0 0.0.255.255
I have changed these ip address to mimic the ip addresses in our site.
As far as I am aware access-list 8 contains all the telephony addresses.
Do I need to add the following:
access-list 8 permit 10.180.0.0 0.0.255.255
Thanks Anthony.
Hello Anthony,
if this is used for a distribute-list in BGP and you don't send a default route to branch office you need to add the statement for DR site voice vlan.
if access-list 8 is used for voip again you need to add the DR site for other reasons.
Hope to help
Giuseppe
Hi Giuseppe,
How do I find out if it is used for a distribute-list in BGP?
Also how can I find out this access-list 8 is used for VOIP.
Can I add this route to access-list 8 during business hours.
I know they are stupid questions but I just want to make sure I am doing the right thing.
Thanks a million
Anthony.
Hello Anthony,
first of all I would check on the branch outer if there is a BGP default route
use sh ip bgp 0.0.0.0
sh ip route 0.0.0.0 to check
if a BGP default route is here STOP the problem is something else.
if a default route is missing the advertisement of the DR site VoIP subnet is needed.
go on the HQ router that has the BGP sessions with the branch router(s)
(you can find it from the branch router doing
sh ip bgp summary and sh ip bgp neighbor)
on the HQ router you need to go at the beginning of BGP process
sh run | beg router bgp
then you need to find out all the lines related to the branch router
the branch can be part of a peer-group
to find the ip address used by the branch use
sh ip bgp branchoffice-ipsubnet
if you see lines like
neigh 1.1.1.1 distribute-list 8 out
or you see something like
neigh 1.1.1.1 route-map name out
then you need to find out what route-map name is (it is later in config or use sh route-map name)
you should find some form of filtering towards the branch
and you need to update the filter to add the DR site voip subnet
if all I've described above is true you can also update the ACL or prefix-list during business hours.
Hope to help
Giuseppe
Hi Giuseppe,
sh ip bgp 0.0.0.0
% Network not in table
ENNISCORTHY#sh ip bgp 10.x.x.1 (ip address of router)
BGP routing table entry for 10.x.x.0/24, version 47
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Multipath: eBGP
Advertised to update-groups:
Local
0.0.0.0 from 0.0.0.0 (192.168.x.x)
Origin incomplete, metric 1, localpref 100, weight 32768, valid, sourced, best
sh ip bgp 0.0.0.0
ENNISCORTHY#sh ip bgp ipaddressof branchofficerouter
BGP routing table entry for 10.2.x.x/24, version 47
Multipath: eBGP
Local
We are not using disrtribute lists.
In order to add in the access-list, I know there is an explicit deny any at the end. Can I just:
conf t
Do I need to copy in all the access-list lines?
Thanks a million for all your help
Anthony.
Hello Anthony,
the ACL can be modified on the fly only in the case of an add like yours the implicit deny any is moved down after the new last statement.
But before on the branch router do
sh ip route 0.0.0.0
sh ip route 10.180.x.y
and ping 10.180.x.y to verify that ip connectivity is really a problem
you can use an extended ping with source=branch site voip ip subnet
destination= 10.180.x.y DR site voip subnet.
if you like because these ip addresses (10/8 ) are private addresses you can post the bgp config of the hub router there is no security risk
(RFC 1918 private ip addresses).
because before changing ACL 8 I would recommend to understand where is used and how.
Last note:
to remove a statement from ACL 8 it is more difficult:
you need to copy to an editor the whole ACL
then you issue
no access-list 8
then you copy back the lines that you want to keep but this is not riskless as you can understand.
It is better to be careful before.
make the ping test I suggested and post the results so we can detect if there is a routing problem.
Hope to help
Giuseppe
Hi Giuseppe,
Hope you had a good weekend.
ENNISCORTHY#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 240, metric 0 (connected), candidate default path
Routing Descriptor Blocks:
* directly connected, via Multilink1
Route metric is 0, traffic share count is 1
ENNISCORTHY#sh ip route 10.180.0.0
% Subnet not in table
ENNISCORTHY#ping 10.180.1.1
Sending 5, 100-byte ICMP Echos to 10.180.1.1, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
When I do a sh ip bgp on the branch router, there is no entry for the 10.180.x.y subnet.
BGP Config:
router bgp 65500
no synchronization
bgp log-neighbor-changes
network 83.71.49.136 mask 255.255.255.252
network 159.134.72.156 mask 255.255.255.252
redistribute ospf 1 route-map local-networks
neighbor 10.1.1.202 remote-as 65500
neighbor 10.1.1.202 next-hop-self
neighbor 159.144.72.57 remote-as 5466
neighbor 159.144.72.57 send-community
neighbor 159.144.72.57 distribute-list 1 in
neighbor 159.144.72.57 route-map increase-odd-localpref in
neighbor 159.144.72.57 route-map odd-community out
distance bgp 20 20 25
distance 115 159.144.72.57 0.0.0.0 Mullingar-prefixes
distance 115 10.1.1.202 0.0.0.0 Mullingar-prefixes
I have changed the ip address in the above config.
Do you recommend making this ACL change now.
Anthony.
Hello Anthony,
just one question:
and
Hope to help
Giuseppe
The bgp setting that I sent you was from one of our HQ routers.
This is the config from one of our branch offices:
router bgp 65500
neighbor 113.94.175.249 remote-as 5466
maximum-paths 4
We have two main HQ routers,
Router1:
router bgp 65500
no synchronization
neighbor 159.134.72.157 remote-as 5466
neighbor 159.134.72.157 send-community
neighbor 159.134.72.157 distribute-list 1 in
neighbor 159.134.72.157 distribute-list 8 out
neighbor 159.134.72.157 route-map increase-odd-localpref in
no auto-summary
access-list 4 deny 10.100.0.0 0.0.255.255
access-list 4 deny 10.12.0.0 0.0.255.255
access-list 4 permit any
Router 2:
router bgp 65500
no synchronization
neighbor 10.1.1.102 remote-as 65500
neighbor 10.1.1.102 next-hop-self
neighbor 10.1.1.102 distribute-list 4 out
neighbor 83.171.50.225 remote-as 5466
neighbor 83.171.50.225 send-community
neighbor 83.171.50.225 distribute-list 1 in
neighbor 83.171.50.225 distribute-list 6 out
neighbor 83.171.50.225 route-map increase-even-localpref in
neighbor 183.71.50.225 route-map even-community out
distance 115 83.71.50.225 0.0.0.0 Mullingar-prefixes
distance 115 10.1.1.102 0.0.0.0 Mullingar-prefixes
no auto-summary
For router 1 I was going to add:
For router 2 I was going to add:
access-list 6 permit 10.180.0.0 0.0.255.255
What do you think?
Anthony.
Hello Anthony,
how the scenario is more clear.
the sessions are done via the service provider so you need to update the acl towards AS 5466
so the lists to be updated are 8 in HQ R1 and 6 on HQ R2
We had some similar problems caused by our internal MPLS network
Hope to help
Giuseppe
Hi Giuseppe,
I added in those two access lists into our two routers in HQ.
I then ran a sh ip bgp in one of our branches and this 10.180 route is not listed as one of the routes, could it take a while for the route to populate into the table.
Do I need to do a soft reset on the two HQ routers?
Anthony.
