ASA 5510 default user&pass not working
Jan 16th, 2009
All,
I just got a ASA 5510 out of the box and the default user&pass are not working.
Imagine now I cant login!
Vlad
Dont take it in consieration.
We reset the password...
godinerik Fri, 01/16/2009 - 11:14
If it's anything like a 5505, when you take it out of the box the first thing you should do is connect to it via the console cable. Hook it up to your asa and the other end to your laptop and use HyperTerminal or Putty to connect to the device via serial (9200, Hardware control none)
You should be presented a prompt ">" and then type ena [enter]
This should get you to the enable prompt, without using a single password.
