Slow download
Jan 16th, 2009
Hi ALL :
I am facing this problem for a some time now.
I have 4503 switch which is connected to PIx and my server.
I have few vlan on the switch ,so when i am intarvlan transfer of data no issue.
But when intervlan data transfer its very slow.
All the vlan have default gateway to the pix.
I have no idea whay is this happening link and port are all have hard coded speed.
ANY suggestion?
Chao
Vishwa
Overall Rating: 3 (1 ratings)
2go2marketing Fri, 01/16/2009 - 10:53
You probably could have omitted the password part of your config. What are your speed/duplex settings on your 4503? If they are 100/full, try changing all of them to auto for the server link. Also, make sure the "flow control" settings are not being used on the server's NIC.
Tshi M Fri, 01/16/2009 - 11:49
what do you get with
sh int status
sh int count er
Tshi M Tue, 01/20/2009 - 05:27
Hi Vishwa,
I actually meant the output from your 4503 switch.
Paolo Bevilacqua Tue, 01/20/2009 - 05:34
Which pix is that ? If you want performance for cross vlan traffic, use 4503 in L3 mode, or an high perfomance pix or router.
vishwancc Tue, 01/20/2009 - 09:27
Hi ALL:
Thanks for the reply the issue is resolved,it was problem with Damm cables.
Chao
Vishwa
