is this the correct config-reg setting?
Answered Question
Jan 16th, 2009
following is a copy of sh redunancy of m 4510R, I just reset the config register to 0x102, is this setting correct for it to comeback up at reboot? (0x102) it is the default at bootup isnt it?...
BOOT =bootflash:cat4000-i9s-mz.122-25.ewa4.bin,1;
BOOTLDR = bootflash:cat4000-i9s-mz.122-25.ewa4.bin
Configuration register = 0x2101 (will be 0x102 at next reload)
thanks
rdavis
Correct Answer by Giuseppe Larosa about 8 years 1 month ago
hello Rob,
yes the config-register command changes the value but not on the fly but at next reload you have changed to 0x102 as desired.
This is normal for config-register in all platforms. (change takes effect at next reload)
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 01/16/2009 - 05:32
hello Rob,
Hope to help
Giuseppe
