Forensics
Jan 16th, 2009
Problem: Verizon calls to report we had two long-distance calls on such and such date to Cuba. The number number they were dialed from comes back as our PRI line. We use Cisco Call Manager 4.1.
How can I determine the device or DID number that made these calls? If I can get the DID number I can link it to a device.
K
Nicholas Matthews Fri, 01/16/2009 - 06:11
  • Red, 2250 points or more
There's a good chance that you have a public IP on your gateway.
There's also a good chance that this public IP doesn't have both TCP and UDP ports 5060 blocked.
That's my guess.
I would apply this ACL to your outside interface:
access-list 101 deny tcp any any eq 5060 log
access-list 101 deny udp any any eq 5060 log
access-list 101 deny tcp any any eq 1720 log
access-list 101 permit ip any any
If this is just two calls, then it may be a user and you would want to check your CDR records.
You may want to read this link anyway:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
hth,
nick
