Connecting two sites with dark fiber
Jan 16th, 2009
I have presently two sites connected with two LAN-X (100Mb i 10Mb).
LAN-X is provided by telco. I will be replacing these links with two dark fiber links.
Here shows how I will connect both sites with dark fiber.
Site 1 (vlan150) 3750<----->3750-E--------fiber1---------3750-E<------>4506 (vlan100) Site 2
Site 1 (vlan150) 3750<----->3750-E--------fiber2---------3750-E<------>4506 (vlan100) Site 2
What would be the best practice to configure these 3750-E to pass vlans between both sites?
Giuseppe Larosa Fri, 01/16/2009 - 09:01
  • Hall of Fame,
    Founding Member
Hello Zbigniew,
L2 connection using trunk ports and allowing all vlans on both sides
if you are using VTP and VTP domain names don't match you need to manually configure the trunk with
swithport trunk enc dot1q
switchport mode trunk
if you instead just want to connect the two sites you can think of a L3 link with a routing protocol over it.
this has the advantage of a better control of broadcasts the fiber will be used only when needed.
Hope to help
Giuseppe
zbigniewkozyra Sat, 01/17/2009 - 06:00
Thank you for a reply.
I need to use l2 because I need to have same vlans available on both sides. Which ports I put in trunk mode? The one between 3750-E? What about ports between 4506 and 3750-E and between 3750 and 3750-E ? Should I create etherchannel using both fiber?
mahmoodmkl Sat, 01/17/2009 - 06:59
  • Gold, 750 points or more
U need to have all the ports which u r using to connected all the devices as trunk links.
Yeh u can make a ether-channel if u want.
Mahmood
wesleyterry Sun, 01/18/2009 - 21:15
  • Bronze, 100 points or more
If you don't use etherchannel, aren't you going to run into STP issues? I'm not an expert, but default properties of spanning tree will disable one of your links. If you do etherchannel, I think you'll basically have a redundant physical connection and twice the bandwidth...
As far as the trunking question, if it is all L2, you're going to need to trunk between all of the links you have in your picture above.
