Router redundancy
Jan 16th, 2009
Hi I hv 2 2811 routers for internet. On one router ADSP link is terminated & on another router I have MPLS inernet link is terminated. I want to segregate the trafic on both the link. which I did via Route-map. Now I want to implement failover between these two routers. If one router internet is goes down then other shud take over. Problem is that both the router have ethernet link not serial link. So if internet goes down or something happens then interface status wud be up always. so i can not use HSRP track command. PLEASE HELP ME
Tshi M Fri, 01/16/2009 - 07:37
I will try to IP SLA combine with a routing protocol such as EIGRP.
kwillacey Fri, 01/16/2009 - 11:17
Yup IP SLA with route maps should work fine, not quite sure you would need the routing though unless you want to advertise your default route or routes to the Internet to your down stream routers.
jain.nitin Fri, 01/16/2009 - 11:26
can you please give me an sample config wht would be the config in my case...
Tshi M Fri, 01/16/2009 - 11:36
Could you post your current configurations and a jpg of your environment? Though, routers configurations should suffice. Are the switches running hsrp between VLANs if any?
