SRST Registration problem
Jan 16th, 2009
I am trying to test a SRST fail over scenario with a few phones(7941,7961 and 7912) When I force a fail over to SRST the phones all register with the Voice Gateway but only the 7912 has its line intact. The 7941s and 7961s are registerd with no line on the phone. Any Ideas? This is CCM 4.2 and Version 12.4(4)XC7 IOS
cbreger_breger Fri, 01/16/2009 - 08:27
I am running the following:
#sh call-manager-fallback all
CONFIG (Version=4.0(3))
Version 4.0(3)
According to this document the 7941/7961s are supported.
ephone-1 Mac:0017.59D3.CEEE TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 9 and Server in ver 5
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:1 caps:9
IP:172.20.1.23 52004 7941 keepalive 3 max_line 2
virverma Fri, 01/16/2009 - 21:11
The 7912 has different
way the phone's user interface is
handled compared to the 7960
Fist, Try upgrading the load on 7912
Also, can I see the config for SRST router
