Cannot Fetch the configuration for 7609-S router into Ciscoworks LMS 2.6
Jan 16th, 2009
I have four 7609S routers that I have discovered in Ciscoworks but cannot fetch the configuration files using the TACACS credentials. I am currently running LMS 2.6.1. Are types routers supported with the current version of Ciscoworks I am running?
drolemc Fri, 01/23/2009 - 14:40
Resource Manager Essentials 4.0.3 (RME) have ability to manage Configuration files, software images, and syslog analysis.Network administrators can assign the protocols to be used in RME for Configuration Management and Software Management.
To define the protocol order for fetching and deploying the configuration files, use Resource Manager Essentials > Admin > Config Mgmt
By default, this is disabled.
For further information click this link.
