speed nonegatiate
Jan 16th, 2009
I do not see this option in ASA. I know it was pix. The ASA config document for 8.0 states that it is there, but when I used the command completion in the box, the option is not there.
sansari Fri, 01/16/2009 - 11:31
No. I think I found what I was looking for. This is from the manual:
By default, the speed and duplex for switch ports are set to auto-negotiate. The default auto-negotiation
setting also includes the Auto-MDI/MDIX feature. Auto-MDI/MDIX eliminates the need for crossover
cabling by performing an internal crossover when a straight cable is detected during the auto-negotiation
phase. Either the speed or duplex must be set to auto-negotiate to enable Auto-MDI/MDIX for the
interface. If you explicitly set both the speed and duplex to a fixed value, thus disabling auto-negotiation
for both settings, then Auto-MDI/MDIX is also disabled.
On pix you can go to the interface and issue the command:
speed nonegotiate
